Aristo
Nov 03, 2011Follower
SRX5308 Bind Management Interface to VLAN
Hi there
I d'like to restrict the access of the SRX5308 web management interface to one VLAN only. This is possible for instance on the GS724. The only thing I was able to do is to limit the login to an ip range (in my case the ip range of a VLAN). But i'm not happy with the solution because the webinterfaces login screen is shown on every VLAN.
Thx for any suggestions!
Best,
Aristo
1 Reply
- jmizoguchiVirtuosoI don't thin it does...:):)
