Subdivisions
Jan 16, 2017Aspirant
SRX5308 Box to Box VPN Connecting but no data passes through.
I have 2 SRX5308's in 2 office locations. Im trying to connect them together via a box to box vpn so the phone vendor can use that connection to pass remote IP phone line and office data to the remote location.
I followed the guide, and have gotten the two sites to connect using the VPN Wizard which was very easy, but i cant browse the network or see any devices on either of the remote lans.
SITE A IP SCHEME: 192.168.1.0
SITE B IP SCHEME: 192.168.0.0
Here is the log from the remote srx5308
Any assistance would be very grateful.
Mon Jan 16 19:55:00 2017 (GMT +0000): [SRX5308] [IKE] INFO: [IPSEC_VPN] IPsec-SA established: ESP/Tunnel 24.105.249.46->108.58.27.178 with spi=164766230(0x9d22216)
Mon Jan 16 19:55:00 2017 (GMT +0000): [SRX5308] [IKE] INFO: [IPSEC_VPN] IPsec-SA established: ESP/Tunnel 108.58.27.178->24.105.249.46 with spi=189853723(0xb50f01b)
Mon Jan 16 19:55:00 2017 (GMT +0000): [SRX5308] [IKE] INFO: Using IPsec SA configuration: 192.168.1.1/24<->192.168.0.0/24
Mon Jan 16 19:55:00 2017 (GMT +0000): [SRX5308] [IKE] INFO: Responding to new phase 2 negotiation: 24.105.249.46[0]<=>108.58.27.178[0]
Mon Jan 16 19:54:57 2017 (GMT +0000): [SRX5308] [IKE] INFO: [IPSEC_VPN] Purged IPsec-SA with proto_id=ESP and spi=99962591(0x5f54edf).
Mon Jan 16 19:54:57 2017 (GMT +0000): [SRX5308] [IKE] INFO: [IPSEC_VPN] Purged IPsec-SA with proto_id=ESP and spi=127074769(0x79301d1).
Mon Jan 16 19:54:57 2017 (GMT +0000): [SRX5308] [IKE] INFO: an undead schedule has been deleted: 'pk_recvupdate'.
Mon Jan 16 19:36:41 2017 (GMT +0000): [SRX5308] [IKE] INFO: [IPSEC_VPN] IPsec-SA established: ESP/Tunnel 24.105.249.46->108.58.27.178 with spi=127074769(0x79301d1)
Mon Jan 16 19:36:41 2017 (GMT +0000): [SRX5308] [IKE] INFO: [IPSEC_VPN] IPsec-SA established: ESP/Tunnel 108.58.27.178->24.105.249.46 with spi=99962591(0x5f54edf)
Mon Jan 16 19:36:41 2017 (GMT +0000): [SRX5308] [IKE] INFO: Using IPsec SA configuration: 192.168.1.1/24<->192.168.0.0/24
Mon Jan 16 19:36:41 2017 (GMT +0000): [SRX5308] [IKE] INFO: Responding to new phase 2 negotiation: 24.105.249.46[0]<=>108.58.27.178[0]
Mon Jan 16 19:36:40 2017 (GMT +0000): [SRX5308] [IKE] INFO: Sending Informational Exchange: notify payload[INITIAL-CONTACT]
Mon Jan 16 19:36:40 2017 (GMT +0000): [SRX5308] [IKE] INFO: ISAKMP-SA established for 24.105.249.46[500]-108.58.27.178[500] with spi:453f02470f29a64c:f4a7ed0b8d0a597d
Mon Jan 16 19:36:40 2017 (GMT +0000): [SRX5308] [IKE] INFO: NAT not detected
Mon Jan 16 19:36:40 2017 (GMT +0000): [SRX5308] [IKE] INFO: NAT-D payload matches for 108.58.27.178[500]
Mon Jan 16 19:36:40 2017 (GMT +0000): [SRX5308] [IKE] INFO: NAT-D payload matches for 24.105.249.46[500]
Mon Jan 16 19:36:40 2017 (GMT +0000): [SRX5308] [IKE] INFO: Received Vendor ID: KAME/racoon
Mon Jan 16 19:36:40 2017 (GMT +0000): [SRX5308] [IKE] INFO: For 108.58.27.178[500], Selected NAT-T version: RFC 3947
Mon Jan 16 19:36:40 2017 (GMT +0000): [SRX5308] [IKE] INFO: Received Vendor ID: DPD
Mon Jan 16 19:36:40 2017 (GMT +0000): [SRX5308] [IKE] INFO: Received Vendor ID: RFC 3947
Mon Jan 16 19:36:40 2017 (GMT +0000): [SRX5308] [IKE] INFO: Received Vendor ID: draft-ietf-ipsec-nat-t-ike-02
Mon Jan 16 19:36:40 2017 (GMT +0000): [SRX5308] [IKE] INFO: Received Vendor ID: RFC XXXX
Mon Jan 16 19:36:40 2017 (GMT +0000): [SRX5308] [IKE] INFO: Beginning Identity Protection mode.
Mon Jan 16 19:36:40 2017 (GMT +0000): [SRX5308] [IKE] INFO: Received request for new phase 1 negotiation: 24.105.249.46[500]<=>108.58.27.178[500]
Mon Jan 16 19:36:40 2017 (GMT +0000): [SRX5308] [IKE] INFO: Configuration found for 108.58.27.178[500].
Mon Jan 16 19:36:22 2017 (GMT +0000): [SRX5308] [IKE] NOTIFY: The packet is retransmitted by 108.58.27.178[500].
Mon Jan 16 19:36:13 2017 (GMT +0000): [SRX5308] [IKE] ERROR: Malformed cookie received or the spi expired.
Mon Jan 16 19:36:12 2017 (GMT +0000): [SRX5308] [IKE] NOTIFY: The packet is retransmitted by 108.58.27.178[500].
Mon Jan 16 19:36:07 2017 (GMT +0000): [SRX5308] [IKE] INFO: Adding IKE configuration with identifier "Rehab_Alt_VPN"
Mon Jan 16 19:36:07 2017 (GMT +0000): [SRX5308] [IKE] INFO: Adding IPSec configuration with identifier "Rehab_Alt_VPN"
Mon Jan 16 19:36:03 2017 (GMT +0000): [SRX5308] [IKE] ERROR: Malformed cookie received or the spi expired.
Mon Jan 16 19:36:02 2017 (GMT +0000): [SRX5308] [IKE] NOTIFY: The packet is retransmitted by 108.58.27.178[500].
Mon Jan 16 19:35:53 2017 (GMT +0000): [SRX5308] [IKE] ERROR: Malformed cookie received or the spi expired.
Mon Jan 16 19:35:52 2017 (GMT +0000): [SRX5308] [IKE] NOTIFY: The packet is retransmitted by 108.58.27.178[500].
Mon Jan 16 19:35:43 2017 (GMT +0000): [SRX5308] [IKE] ERROR: Malformed cookie received or the spi expired.
Mon Jan 16 19:35:42 2017 (GMT +0000): [SRX5308] [IKE] NOTIFY: The packet is retransmitted by 108.58.27.178[500].
Mon Jan 16 19:35:33 2017 (GMT +0000): [SRX5308] [IKE] ERROR: Malformed cookie received or the spi expired.
Mon Jan 16 19:35:32 2017 (GMT +0000): [SRX5308] [IKE] NOTIFY: The packet is retransmitted by 108.58.27.178[500].
Mon Jan 16 19:35:23 2017 (GMT +0000): [SRX5308] [IKE] ERROR: Malformed cookie received or the spi expired.
Mon Jan 16 19:35:23 2017 (GMT +0000): [SRX5308] [IKE] NOTIFY: The packet is retransmitted by 108.58.27.178[500].
Mon Jan 16 19:35:13 2017 (GMT +0000): [SRX5308] [IKE] ERROR: Malformed cookie received or the spi expired.
Mon Jan 16 19:35:12 2017 (GMT +0000): [SRX5308] [IKE] NOTIFY: The packet is retransmitted by 108.58.27.178[500].
Mon Jan 16 19:35:03 2017 (GMT +0000): [SRX5308] [IKE] ERROR: Malformed cookie received or the spi expired.
Mon Jan 16 19:35:02 2017 (GMT +0000): [SRX5308] [IKE] NOTIFY: The packet is retransmitted by 108.58.27.178[500].
Mon Jan 16 19:34:57 2017 (GMT +0000): [SRX5308] [IKE] INFO: IKE configuration with identifier "to-jericho" deleted sucessfully
Mon Jan 16 19:34:57 2017 (GMT +0000): [SRX5308] [IKE] INFO: an undead schedule has been deleted: 'isakmp_ph1resend'.
Mon Jan 16 19:34:57 2017 (GMT +0000): [SRX5308] [IKE] INFO: an undead schedule has been deleted: 'purge_remote'.
Mon Jan 16 19:34:57 2017 (GMT +0000): [SRX5308] [IKE] INFO: Purged ISAKMP-SA with spi=7a403ea10500d622:d069e0c1bbc214a0.
Mon Jan 16 19:34:57 2017 (GMT +0000): [SRX5308] [IKE] WARNING: no phase2 bounded.
Mon Jan 16 19:34:57 2017 (GMT +0000): [SRX5308] [IKE] INFO: Purged ISAKMP-SA with spi=30a697333da6385d:57f453c5082933f8.
Mon Jan 16 19:34:57 2017 (GMT +0000): [SRX5308] [IKE] INFO: IPSec configuration with identifier "to-jericho" deleted sucessfully
Mon Jan 16 19:34:57 2017 (GMT +0000): [SRX5308] [IKE] WARNING: no phase2 found for "to-jericho"
Mon Jan 16 19:34:53 2017 (GMT +0000): [SRX5308] [IKE] INFO: Received Malformed packet of payload length 64365 and total length 40.
Hi Subdivisions
Can you try to change the start ip from 192.168.0.254 to 192.168.0.0?then have atry?
Regards
- ChenXNETGEAR Expert
Hi Subdivisions
Welcome to the community!
I see your log:
Can you show me your vpn config and lan subnet?
Or you can follow this:
- SubdivisionsAspirant
I think this is what you need, i blocked out the key for security reasons..
http://mail.paston.com/subdivisions/ra1.jpg
http://mail.paston.com/subdivisions/ra2.jpg
http://mail.paston.com/subdivisions/ra3.jpg
http://mail.paston.com/subdivisions/ra4.jpg
Hi Subdivisions
Regards
