LECYNKAR
Aug 29, 2011Aspirant
SRX5308 Hosting multiple websites in the DMZ not working! HELP!
I have a group of 5 static IP's that I use to host websites. I have the SRX5308 set to use 1 WAN port with one of the IP's and added the rest of the IP's as "Secondary IP's". Next I have multiple IP'...
LECYNKAR
OK thanks to everyone for your input!..
I got it to work, but it doesn't make much sense.. I reset to defaults, that didn't work, then flashed back to 3.0.7-29, re-setup the secondary IP's. Then added my WAN to DMZ rules. Things seemed to be working, so I then flashed back up to 3.0.7-45. Still working, which is great!
So like I said doesn't make a whole lot of sense, but thank goodness it's working. One thing that doens't seem to work is blocking outgoing traffic on the DMZ. If I create a rule to block all traffic on the DMZ, and call my website from an external internet connection, it stills gets returned, even when I change the LAN to WAN to block ALL. Seems to me if I set that rule to block all outgoing traffic it should do just that block the return of the HTTP request? Is this a bug?
