LECYNKAR
Aug 29, 2011Aspirant
SRX5308 Hosting multiple websites in the DMZ not working! HELP!
I have a group of 5 static IP's that I use to host websites. I have the SRX5308 set to use 1 WAN port with one of the IP's and added the rest of the IP's as "Secondary IP's". Next I have multiple IP'...
jmizoguchi
Aug 29, 2011Virtuoso
sounds like firmware may not loaded good on first time.
if block outgoing for entire service it should block it to all default ports on router or one specified.
did you test from physically out of your network?
