GDRitter
May 05, 2017Aspirant
SRX5308 How to isolate some clients so they have internet only and can't contact peers
We are a small business with an SRX5308. I have a basic, consumer WiFi router also hooked into it. What I want to know, is if there is a way to configure these so that known work computers o...
DaneA
May 10, 2017NETGEAR Employee Retired
Let me inform you that the WNDR3400 router (even if its configured as an access point) does not support VLAN. The reason why it works when you connect the WNDR3400 to port 4 of the SRX5308 which is a member of VLAN 2 is because the static IP address set on the WNDR3400 is within the IP range of VLAN 2 configured on the SRX5308. The moment you connect the WNDR3400 to other ports (ports 1-3) of the SRX5308, it will not work because ports 1-3 belongs to the default VLAN 1 which has a different IP range.
Pertaining to your current network setup, here are my suggestions:
a. Add another WNDR3400 router configured as an access point and dedicate it only for VLAN 1. Or,
b. Replace the WNDR3400 with an access point wherein you can create a wireless network dedicated to each VLAN. If you will choose this option, refer again to my suggested network setup. You could still use your existing GS748T switch for the network setup I suggest. However, since the GS748T doesn't support PoE, I suggest you the WN203 access point. Check the WN203 specifications here.
DaneA
NETGEAR Community Team
GDRitter
May 10, 2017Aspirant
Thanks so much for your help Dane.
Could I insert a VLAN aware switch such as GSS108E that then has a port defined VLAN between the GS748T and WNDR3400 to enable what I'm after? I happen to have a GSS108E laying on the shelf and I don't want to spend more $ if I can avoid it.
If not, I'll probably just leave the WNDR3400 on LAN4 of the SRX5308 and guests will have a bit weaker signal strength downstairs.
Thanks again!
- DaneAMay 11, 2017NETGEAR Employee Retired
If you just wanted the wireless connections downstairs dedicated only for guests, access and follow the steps on the article below:
How do I set up one or more VLANs between a NETGEAR ProSAFE firewall and a smart switch?
Note: From the article, the SRX5308 and M4100-12G switch are used. You already have an SRX5308 and you can use your existing GS748T on this setup. Also from the article above, VLAN 1 and VLAN 5 are used an an example. I suggest that you follow all the steps indicated on the article so that we will be in the same pace. The goal here is to have both VLAN 1 (Private) and VLAN 5 (Guest) to have internet access but no access to each VLAN.
Answer the questions below:
a. Are you able to access the internet when you connect PC1 to port 6 of the GS748T? If you follow the article, port 6 is on VLAN 1 or Private VLAN.
b. Are you able to access the internet when you connect PC2 to port 11 of the GS748T? If you follow the article, port 11 is the only port on VLAN 5 or Guest VLAN.
c. From PC1, are you able to get replies when you ping the IP address of PC2?
d. From PC2, are you able to get replies when you ping the IP address of PC1?
Note: If your answers above are: (a)Yes, (b)Yes, (c)No, and (d)No, it means that you have really followed the steps from the article. Proceed to the next phase below.
Remember that port 11 is the only port on VLAN 5 (Guest VLAN) which is untagged (U) and the rest of the ports of the GS748T belong to VLAN 1 (Private VLAN). Here are the steps below:
1. Set a static IP address to WNDR3400 (configured as an access point) that is within the IP range of VLAN 5.
2. Connect the WNDR3400 to port 5 of the GS748T.
3. Connect to the SSID configured on the WNDR3400 and check if you are able to go online wirelessly.
Note: Be reminded that only the Guest VLAN will be able to go online wirelessly.
Let us know the result.
DaneA
