hurricanejanko
Jul 29, 2015Aspirant
SRX5308 information about DHCP leases, bandwidth, users data
I just purchased SRX5308 and it looks I cannot find any option to see list of all active dhcp leases, activity of users etc. I can only monitor bandwidth per port.(!!!) Tell me I am wrong and pl...
DaneA
Jul 30, 2015NETGEAR Employee Retired
Hi hurricanejanko,
On the web-GUI of the SRX5308, click on Network Configuration > LAN Settings > LAN Groups to check DHCP leases. Check the screenshot below:
Check pages 96-100 of the SRX5308 reference manual here.
Also, I think it is not possible to monitor the activity of users via the SRX5308 web-GUI.
DaneA
Netgear Community Team
- hurricanejankoJul 31, 2015Aspirant
Great ! It took few minutes to load up but it works so fine by me. Can I see somehow how much Tx/Rx goes to one IP or is being sent to per VLAN ?
- DaneAAug 02, 2015NETGEAR Employee Retired
Hi hurricanejanko,
On the web-GUI of the SRX5308, go to Network Configuration > LAN Settings then click the Advanced option arrow in the upper right of the LAN Setup screen. The IPv4 LAN Advanced screen displays.
Then, click on LAN Traffic Meter tab. The LAN Traffic Meter screen displays. Then, click Edit button to the right of the account for which you want to view the statistics.
Kindly check pages 359-361 of the SRX5308 reference manual here for more information.
Hope this helps. :smileyhappy:
DaneA
