herrmann_daniel
Aug 20, 2015Aspirant
SRX5308 Load balancing with protocol binding problem
I have 3 Internet connections in load balancing mode. All outgoing traffic to a specific IP adress (mail hub) must go through specific WAN port where I have a dedicated IP address. If any other WAN port is used the mail hub rejects the message.
Protocol binding has been setup but when this spesific WAN port fails it switches to any other WAN port available and emails are rejected. I would prefer no outgoing packets at all if the spesific WAN port is down to avoid rejected mails and the internal mail server could send the message again when the WAN port becomes available.
- DaneANETGEAR Employee Retired
Hi herrmann_daniel,
A few questions:
a. What is the current firmware version of your SRX5308?
b. What load balancing method is currently selected?
Kindly try these steps:
1. On the web-GUI of the SRX5308, go to Security > Firewall > Attack Checks. Make sure the IPv4 radio button is selected by default on the upper right of the screen.
2. Uncheck "Block UDP Flood" under LAN Security Checks.
3. Click Apply.
Hope this helps. Welcome to the community :smileyhappy:
DaneA
Netgear Community Team
- herrmann_danielAspirantHi DaneA, a. Firmware is 4.3.3-5 b. Load balancing method is Weighted LB Block UDP flood is not checked. What is the behavior I should expect if protocol binding is configured and the internet connection on the WAN port that is programmed is down? Should packets go through any other WAN port available? Or should they just not go through? Regards, Daniel
Hi herrmann_daniel,
Thanks for your response.
With regard to your concern, since you have 3 WAN connections, let say for example WAN1 port goes down, all of the services that are binded to it will be all down and it will not switch to any other WAN ports.
DaneA
