select1967
Mar 21, 2016Aspirant
Srx5308 multiple vlans
Hi I have a internet connection with vlan 50 private and vlan 3 public vlan is networked by ISP (vapour). I now now need public access (vlan 3) on the uses who use vlan 50 note...
JohnRo
Mar 22, 2016NETGEAR Employee Retired
Hello select1967,
The WAN ports are not VLAN aware. I think the closest thing that can be applied is by using protocol binding, the problem is the clients from both networks will be able to communicate. Let me see if I can find more.
Thanks,
