dysonp's avatar
dysonp
Srxn 3205
I was using a DG 834 with my SRXN3205 but I have recently changed to BT Infinity so now I have to use their modem instead of my DG834. Everything works apart from my VPN. When I try and connect via VPN, it does not get past the Phase1 transmit and fails. Has anybody else had problems with VPN using BT Infinity. I have not changed any settings on my SRXN3205 which used to work with my old ISP supplier.
Many thanks
  • that is why your issues are
    public IP - publicly routable IP- ISP released iP
  • Sorry but I still don't understand what you are saying. *I had the
    same setup before I changed ISP and it worked so *I don't understand
    why it would not work now.
    check the WAN and it is public IP or not.. you just assuming so I wouldn't know
    it's obvious something has changed
ProSupport for Business
