GMen
Jun 15, 2016Aspirant
SRXN3205 reset not working
Hi, my ProSafe Router isn't resetting the security credentials. The admin in my office has left without telling us the password, I tried to reset the settings to factory defaults by: 1. Whil...
GMen
Jun 16, 2016Aspirant
Hi,
Thanks for your reply.
Unfortunately, every command I issue isn't working.
It tells me command not found.
Eg when I issue help net
It tells me the command does not exist.
train_wreck
Jun 16, 2016Luminary
hmm, are you logging in as a user with admin-level privileges?
immediately after you login, you can type a question mark (?) and you will get a list of available commands.
