arturog
Feb 28, 2013Aspirant
SSL VPN on FVS336G
I have been able to successfully setup an SSL VPN on a FVS336GV1 with the latest firmware but have several issues with it. All of them on Windows XP or 7 clients. The performance is very low with j...
arturog
Mar 16, 2013Aspirant
Ok, that solved the issue. I am bit puzzled however. I am using SSL VPN and mode config tab is just under IPSEC VPN. In addition there was nothing mentioned in the SSL VPN guide in netgear's web site.
I think netgear should revise this in terms of usability.
- Sep 04, 2015Retired_Member
