arturog
Feb 28, 2013Aspirant
SSL VPN on FVS336G
I have been able to successfully setup an SSL VPN on a FVS336GV1 with the latest firmware but have several issues with it. All of them on Windows XP or 7 clients. The performance is very low with j...
arturog
Mar 19, 2013Aspirant
Hi, what I mean is you said:
quote
Edit the file "LMHOSTS" Add the following lines to this file - then save the file:
end quote
But you didn't post the line that has to be added.
Regards
quote
end quote
Regards
- Sep 04, 2015Retired_Member
