msbandco
Sep 11, 2017Aspirant
This Serial number has already been registered in our system by a support representative.
Hi. I am struggling to make contact with technical support by phone / email / online to resolve this issue and similar posts with this issue advise to contact support. The FVS318N was purchased new i...
- Sep 14, 2017
Just an update. I got a feedback that your FVS318N is now registered under your name. Kindly check it. :)
Since your concern has been addressed and if ever you have no further inquiries, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
NETGEAR Community Team
DaneA
Sep 12, 2017NETGEAR Employee Retired
Hi msbandco,
Welcome to the community! :)
If the FVS318N you bought last August 2017 is already registered last January 2013 then you might have purchased a second hand unit. Kindly send a picture of the serial number labeled on your FVS318N that you bought last August 2017 via private message for verification.
May I know what is your problem on the FVS318N?
DaneA
