msbandco
Sep 11, 2017Aspirant
This Serial number has already been registered in our system by a support representative.
Hi. I am struggling to make contact with technical support by phone / email / online to resolve this issue and similar posts with this issue advise to contact support. The FVS318N was purchased new i...
- Sep 14, 2017
Just an update. I got a feedback that your FVS318N is now registered under your name. Kindly check it. :)
Since your concern has been addressed and if ever you have no further inquiries, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
NETGEAR Community Team
DaneA
Sep 14, 2017NETGEAR Employee Retired
DaneA
msbandco
Sep 14, 2017Aspirant
I can confirm it is now correctly registered to our account. Thank you.
