sktn77a
Aug 10, 2016Virtuoso
Using wifi router as an access point
OK, this is an oldie but a goldie! I have an old Netgear FWAG114 a/b/g wireless router that I'm using as an access point. I've disabled DHCP (my Netgear WNR2000 is assigning IP addreses) and connec...
- Aug 14, 2016
Hi sktn77a,
As far as I know, the proper way is to connect the WiFi router configured as Access Point to the LAN port of the main router. It is because the main router (in your setup, its the WNR2000) is the one that will provide local IP addresses to the wireless clients connected to the SSID of the WiFi router configured as Access Point that is why it should be connected via the LAN port.
DaneA
NETGEAR Community Team
DaneA
Aug 11, 2016NETGEAR Employee Retired
Hi sktn77a,
I have also configured WiFi routers to be used as access points and it should be connected to the LAN port of the router not to the WAN port.
DaneA
