flattened
Oct 11, 2016Apprentice
UTM9 Mac OSX Sierra - IPSec VPN
Hi all, I have used the very useful PDF to enable a Mac on latest OS X Sierra to the UTM 9. PDF https://docs.google.com/viewer?a=v&pid=sites&srcid=a29zc2Jvc3MuY29tfG1haW58Z3g6NzZkNDZhYTNiYTkw...
- Dec 09, 2016
I'd like to end this as closed. We achieved the required result by reverting back to standard PPTP using a 3rd party paid app on the Mac called Shimo.
Danthem
Oct 26, 2016NETGEAR Employee Retired
Just to be sure, is your local subnet on the client side different from the LAN subnet you're trying to access on the UTM side of things?
Please also check for any "ANY"-service inbound rules on the UTM, if you can, disable all rules on the UTM temporarily for testing. If that helps, turn them on one by one to find out which one interfers.
Other things to check on the UTM side would be static routes.
flattened
Dec 09, 2016Apprentice
