PasavICT
Jul 29, 2016Aspirant
VLAN Configuration Wifi Guest
We want to setup a new network situation with multiple VLANS. We have a SRX5308, with setuip VLAN 1 main network VLAN12 guest Network VLAN1 has no DHCP, and VLAN12 is setup as DHCP only for VLAN1...
DaneA
Aug 03, 2016NETGEAR Employee Retired
Hi PasavICT,
The GS108P is a Gigabit unmanaged switch that supports PoE. It does not have a VLAN feature. Kindly check the GS108P data sheet here as reference.
I recommend you the GS110TP Gigabit PoE Smart switch. The GS110TP supports VLAN. Kindly check the GS110TP data sheet here.
Kindly access the articles below as reference guide:
IEEE 802.1Q VLAN Example Configuration
How do I set up one or more VLANs between a NETGEAR ProSAFE firewall and a smart switch?
DaneA
NETGEAR Community Team
