Hetz
Jan 11, 2019Follower
VPN Client License Key reset
I own two 5 license Netgear VPN ProSafe VPN client keys that need to get reset. From what I've found in the community forum, it appears that I should post my request here.
Last year, I had switche...
- Jan 11, 2019
Hetz,
We are able to reset all the licenses that you sent as per your request. You may now try to install the key.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
JohnC_V
Jan 11, 2019NETGEAR Employee Retired
Hi Hetz,
Welcome to our community! :)
May you be able to send me via pm the license key and the e-mail address that needs to reset?
I look forward to your pm.
