SebTracor
Jun 19, 2019Tutor
VPN Client License Key reset
Hello team, We have a problem with license pro VPN 2 of our PC are crashed and licenses are burned Is it possible to reset the license code to install it on news notebooks ? Thanks fo...
- Jun 20, 2019
I just got a feedback from the higher tier of NETGEAR Support that your VPN license key associated with the e-mail address you have sent via private message has been reset.
You may now register the VPN license key to your new notebooks.
Since your concern has been resolved and you have no further concerns, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
NETGEAR Community Team
