JorisN
Feb 28, 2017Initiate
VPN Client Lite license key
We purchased 6 SRX5308 firewalls in may of 2011. At that time I didn't know there was a VPN Client for windows available. Now I would like to use it, but I need a license key to install it, which I ...
ms1234
Mar 22, 2017Aspirant
Hello,
Have been using VPN Client Lite for years with a few different Netgear routers with much success for reaching home and remote offices, etc. Recently uninstalled VPN Client Lite on one host before re-image... which is supposed to release the license key but apparently that did not happen. Now trying to set up again and tells me KEY is in use on another machine. I even went back and checked the VM I'd made of that machine before re-image. Indeed the app was uninstalled while online.
Currently unable to create a support ticket, phone or chat session. These seem to have expired.
Would a moderator or support be kind enough to PM me so I can send the KEY # for reset.
Thanks in advance,
Matt
DaneA
Mar 23, 2017NETGEAR Employee Retired
Welcome to the community! :)
It seems you have already opened an online case with NETGEAR Support. I also inquired it to the NETGEAR Support team. Kindly wait for their response.
DaneA
NETGEAR Community Team
- DaneAMar 26, 2017NETGEAR Employee Retired
I just want to follow-up on your concern. I believe your VPN Lite license key has been reset already. Were you able to try to register it?
DaneA
- ms1234Apr 02, 2017Aspirant
Support got in touch. Key is reset and all is resolved. Thank you and best regards.
