Augello
Feb 14, 2019Tutor
VPN Client VPNG01L VPNG05L
I need a license for the Netgear VPN Client Pro VPNG05L or VPNG01L.
In the past I purchased it from Netgear4Less.com but can't find it anymore.
EOL or not I need a license and am not in a possiti...
DaneA
Feb 17, 2019NETGEAR Employee Retired
Hi Augello,
I suggest you to kindly check your past e-mails you got from Netgear4Less.com and you might find the VPN license key you have purchased from them.
EOL or not I need a license and am not in a possition to change products at this time.
Can anyone help me purchase a KEY?
Both of the VPNG05L or VPNG01L are already EoL. If ever you have already registered your VPNG05L / VPNG01L license keys you have purchased before, kindly send me via private message the e-mail address/es you think that you might have possibly used when you registered it and I'll make a request to have it check.
DaneA
NETGEAR Community Team
Augello
Feb 19, 2019Tutor
Thanks: Your suggestion was spot on.
One other simular issue you might help with is restoring a VPN Lite Client key.
I uninstalled the Netgear ProSafe VPN client Lite 4.6 from a laptop, which should have released the software key. But after installing the client on the user's new laptop the key won't activate.
Can you help?
Mike
- Nodism1125Feb 20, 2019NETGEAR Expert
Hi Mike,
What is the error code when you activate the license key?
- AugelloFeb 20, 2019Tutor
Activation error 34: The license can not be used to activate THE software.
Hi Augello,
Error 34 - Wrong software client.Error message (Your license number cannot be used for activation)
If you are using a VPN Professional Software, please uninstall and install the VPN lite software.
VPN LIte v6.40.004 Download link
VPN Pro Software Version 6.40.004 Download link
