Rembrond
Jun 11, 2018Aspirant
VPNG01L - Reset Lic
Laptop where previous install located crashed. Tried doing a new install, but the netgear lic server wants me to un-install previous copy. That's not going to be possible. I see from previous posts that the key can be reset and then I would be able to reinstall. Tried doing this thru phone support earlier today but after almost two hours on the phone and being transferred four times I got tired of the run around... This should not be this difficult... Any help would greatly be appreciated. Rem
Hi Rembrond,
Welcome to our community! :)
I already forwarded your license key to our engineering team and they were able to reset it successfully. It should work now.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
- JohnC_VNETGEAR Employee Retired
Hi Rembrond,
- RembrondAspirantIt worked great - Thank you!! Wish the phone support people could be as good as you all are!
- Bruno_mechAspirant
Dear Netgear community,
sorry for hijacking this thread, but I do have exactly the same problem. I already tried contacting JohnC who was helpful last time this thread was active. He is by now surley very well retiered and might not be active here any more. Is there anybody else here with connection to neatgear emloyees who could help in my case?
kind regards
Bruno
