vision99
Sep 20, 2016Aspirant
vpn connect from ios 10 iPHone to fvs318v3
Hi, I want to connect an iphone with ios 10 over vpn to the fvs318v3 IOS 10 supports L2TP/IPSec IKEv2/IPSec Cisco IPSec i trieed to connect over ikev2 but i get no connection. in the lo...
- Sep 28, 2016
Hi JohnRo,
thanks for your help.
I try it with another model.
Vision99
JohnRo
Sep 22, 2016NETGEAR Employee Retired
Hello vision99,
Welcome to the community!
I am not sure if iOS10 works the same way as other versions of iOS when using VPN. Take a look at this article and see if it will work for you. I know it is a different version of the FVS but it works the same way.
Let us know if this helps.
Thanks,
- vision99Sep 23, 2016Aspirant
Thanx,
here you can see the configurationwebsite from the router.
an in looks a littebit different :(
in this firmware it is not possible to create users.
- JohnRoSep 23, 2016NETGEAR Employee Retired
Hi vision99,
Sorry, I overlooked the model number. Unfortunately this model/version does not have mode config and users. Let me see if I can find anything for this model.
Thanks,
