vision99
Sep 20, 2016Aspirant
vpn connect from ios 10 iPHone to fvs318v3
Hi, I want to connect an iphone with ios 10 over vpn to the fvs318v3 IOS 10 supports L2TP/IPSec IKEv2/IPSec Cisco IPSec i trieed to connect over ikev2 but i get no connection. in the lo...
- Sep 28, 2016
Hi JohnRo,
thanks for your help.
I try it with another model.
Vision99
JohnRo
Sep 22, 2016NETGEAR Employee Retired
Hello vision99,
Welcome to the community!
I am not sure if iOS10 works the same way as other versions of iOS when using VPN. Take a look at this article and see if it will work for you. I know it is a different version of the FVS but it works the same way.
Let us know if this helps.
Thanks,
vision99
Sep 23, 2016Aspirant
Thanx,
here you can see the configurationwebsite from the router.
an in looks a littebit different :(
- vision99Sep 23, 2016Aspirant
in this firmware it is not possible to create users.
- JohnRoSep 23, 2016NETGEAR Employee Retired
Hi vision99,
Sorry, I overlooked the model number. Unfortunately this model/version does not have mode config and users. Let me see if I can find anything for this model.
Thanks,
- JohnRoSep 26, 2016NETGEAR Employee Retired
Hi vision99,
I tried looking for any articles I can give you but ended up with nothing. I don't see a way for the FVS318v3 to connect to iPhone's VPN without using mode config, I don't believe it's going to work using regular IPSec setup. It is best to upgrade your router to a higher model like the FVS318Gv2 or the FVS336Gv3.
Thanks,
- vision99Sep 28, 2016Aspirant
Hi JohnRo,
Vision99
