vision99
Sep 20, 2016Aspirant
vpn connect from ios 10 iPHone to fvs318v3
Hi, I want to connect an iphone with ios 10 over vpn to the fvs318v3 IOS 10 supports L2TP/IPSec IKEv2/IPSec Cisco IPSec i trieed to connect over ikev2 but i get no connection. in the lo...
- Sep 28, 2016
Hi JohnRo,
thanks for your help.
I try it with another model.
Vision99
vision99
Sep 23, 2016Aspirant
Thanx,
here you can see the configurationwebsite from the router.
an in looks a littebit different :(
vision99
in this firmware it is not possible to create users.
- JohnRoSep 23, 2016NETGEAR Employee Retired
Hi vision99,
Sorry, I overlooked the model number. Unfortunately this model/version does not have mode config and users. Let me see if I can find anything for this model.
Thanks,
- JohnRoSep 26, 2016NETGEAR Employee Retired
Hi vision99,
I tried looking for any articles I can give you but ended up with nothing. I don't see a way for the FVS318v3 to connect to iPhone's VPN without using mode config, I don't believe it's going to work using regular IPSec setup. It is best to upgrade your router to a higher model like the FVS318Gv2 or the FVS336Gv3.
Thanks,
- vision99Sep 28, 2016Aspirant
Hi JohnRo,
Vision99
- JohnRoSep 28, 2016NETGEAR Employee Retired
Hi vision99,
It's my pleasure to help! BTW, you can use that same article I posted previously once you got a newer model. If one of my posts has answered your queries, we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Thanks,
