BSM_ENGINEERING
Dec 06, 2018Tutor
VPN Connected, but know what to do?
Ok, so I've been able to make VPN connectivity between two locations but cannot find the remote computers in my File Explorer. Am I supposed to use Remote Desktop or something else to find these mac...
JohnC_V
Dec 07, 2018NETGEAR Employee Retired
Hi BSM_ENGINEERING,
Well, it depends on how you wanted to access the files in your network. You may use RDP or you may share the specific folder in public or to a specific user so that you can have an access to it.
I hope this articles would help.
- How to view a list with all shared network folders in Windows
- How to Access Network Resources Over a VPN
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
