Dion07
Feb 27, 2017Aspirant
VPN Firewall Comparison
I currently have the SRXN3205 VPN Firewall installed at my home so that I may have a VPN site to site connection from my house to my office and other work sites. After installing it I found out quite...
DaneA
Feb 28, 2017NETGEAR Employee Retired
Hi Dion07,
I believe you are referring to the FVS318Gv2. Its product code in North America is FVS318G-200NAS.
About IPSec VPN, here are the differences:
a. The FVS318Gv2 has a VPN throughput of 30Mbps while the SRXN3205 has a VPN throughput of 20Mbps.
b. The FVS318Gv2 supports 12 dedicated VPN tunnels while the SRXN3205 supports 5 dedicated VPN tunnels.
If you are looking for other ProSAFE VPN Firewall as alternative to the FVS318Gv2, you may check on the FVS336Gv3, FVS318N and SRX5308. See their specifications and comparison here.
DaneA
NETGEAR Community Team
- Dion07Feb 28, 2017Aspirant
DaneA Yes, I am currently looking at the FVS318G-200NAS.
I currently have the SRXN3205 and wanted to verify that the FVS318G-200NAS (or FVS318Gv2) would be a viable replacement as I am not 100% sure and would like a second opinion. :)
- DaneAMar 02, 2017NETGEAR Employee Retired
Let me also inform you that if you purchased the FVS318Gv2, it is bundled with a VPN Lite Client software that has 1 Lite license key included for free. You can use this in setting up a client-to-box VPN. For more information, kindly read this article.
DaneA
NETGEAR Community TEam
- DaneAMar 05, 2017NETGEAR Employee Retired
I just want to follow-up. Let us know if you have further questions.
Otherwise, if ever your concern has been addressed / resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
