marcobravissimo
Oct 09, 2017Aspirant
VPN gateway to gateway SRX5308 IPsec SA Established but no traffic
I have 2 srx5308 last firmware upgrated. i I have two SRX5308 connected gateway to gateway, connect IPsec SA Established but do no traffic. One of them runs the trafficbut the arrive to lan desti...
marcobravissimo
Oct 16, 2017Aspirant
JohnC_V
Oct 16, 2017NETGEAR Employee Retired
Thank you for your attachments. How is everything connected from these firewalls? Are they connected directly to the back of the modem or Is it connected to a router? If it is still connected to a router, I may advise you to double check if the router was set to full bridge mode. Also, update the firmware to latest version.
Thank you!
