Preformed2019
Jan 16, 2019Tutor
VPN licence reset
Hello Everyone;
I have SRX3508 Firewall and VPN Client softwares which I would like to reset the licence so I can use it on other PC. I've had a hard time reaching the correct support team resp...
- Jan 16, 2019
We successfully reset the license key. Please try if you can now install it.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
JohnC_V
Jan 16, 2019NETGEAR Employee Retired
