netpilot
Nov 18, 2016Aspirant
VPN Lite Client License not available after uninstall
The VPN Lite Client which came with the router was istalled on a Win 8.1 pro machine and worked well. Due to a new laptop the client has to be installed on that new machine now, which is running unde...
- Dec 13, 2016
Hi netpilot,
I would like to inform you that your license has now been reset. It should be usable now on your installation.
Have a great day!
Thanks,
DaneA
Nov 27, 2016NETGEAR Employee Retired
Hi netpilot,
Just want to follow-up. Were you able to open an online case with NETGEAR Support to help you with your concern? If yes, kindly keep us posted.
DaneA
NETGEAR Community Team
- netpilotNov 28, 2016Aspirant
Hi ,
thaks for your reply.
I was not able to contact support. I have not found a way to open a call regarding just the software. The system always asks for a (hw) product. Unfortunately my router is out of the free service periode and so I cannot open a call without havin a service contract ( that's what I have understood so far...). But maybe I have not found the right way to open tha call anyway. So please advise what to do.
Thanks!
-np
- JohnRoNov 28, 2016NETGEAR Employee Retired
Hi netpilot,
I'll request for the reset on this one. Can you please PM me your license key? We appreciate your patience.
Thanks,
- JohnRoDec 13, 2016NETGEAR Employee Retired
Hi netpilot,
Have a great day!
Thanks,
- netpilotDec 15, 2016Aspirant
Thanks again for the really good support!
The license key could be applied to the newly installed software as it should be.
-np
