vfandrea
Jul 10, 2017Aspirant
VPN logon fails
I have setup a VPN connection to be used from iOS devices (iOS Version 10), but I always receive a "login failed" error on my mobile device, even if user and password are correct (for sure). Connection Tested also from Android device, same issue
This are the settings (Internal LAN IP is 172.31.1.0 / 24):
Firewall side:
Mode Config:
Record Name: modeConfigIOS
First Pool: Start IP: 192.168.224.1
End IP: 192.168.224.100
Second & Thirs pools: blank
WINS Server: Primary: 172.31.1.1 <My Internal LAN Wind Server IP>
Secondary: blank
DNS Server: Primary: 172.31.1.1 <My Internal LAN DNS Server IP>
Secondary: blank
PFS Key Group:<Checked> DH Group 2 (1024 bit)
SA Lifetime: 300 Seconds
Encryption Algorithm: AES-128
Integrity Algorithm: SHA-1
Local IP Address: 172.31.1.0
Local Subnet Mask: 255.255.255.0
IKE Policy:
Do you want to use Mode Config Record? YES
Select Mode Config Record: modeConfigIOS
Policy Name: for_iOS
Type: Responder
Exchange Mode: Main
Local
Select Local Gateway: WAN1
Indetifier Type: FQDN
Identifier: fvs1_local.com
Remote
Identifier Type: FQDN
Identifier: 0.0.0.0
Authentication Algorithm: SHA-1
Authentication Method: pre-shared key
pre-shared key: 12345678 <Tested with different one>
Diffie-Hellman (DH) Group: Group 2 (1024 bit)
SA-Lifetime (sec): 300
Enable Dead Peer Detection: no
XAUTH Configuration: Edge Device
Authentication Type: User Database
User Settings:
User Type: IPSEC VPN User
On iOS Device:
Type: IPSec
Description: <VPN Name>
Server: My Public IP
Account: <TheUsername>
Password: <Blank, I enter it at every connection>
Use Certificate: OFF
Group Name: blank
Secret: 12345678
proxy: No
When i try to connect, the mobile device ask for user and password and then shows a User Authentication Error.
On VPN LOG I have these entries (for security reason, my public IP has been removed):
Mon Jul 10 09:53:14 2017 (GMT +0200): [SRX5308] [IKE] ERROR: Received mode config from 31.159.216.207[500], but we do not have ISAKMP-SA. Mon Jul 10 09:53:14 2017 (GMT +0200): [SRX5308] [IKE] INFO: an undead schedule has been deleted: 'ph1_main'. Mon Jul 10 09:53:14 2017 (GMT +0200): [SRX5308] [IKE] ERROR: Failed to find proper address pool with id -1 Mon Jul 10 09:53:14 2017 (GMT +0200): [SRX5308] [IKE] INFO: Sending Informational Exchange: delete payload[] Mon Jul 10 09:53:14 2017 (GMT +0200): [SRX5308] [IKE] INFO: Login failed for user "supportios" Mon Jul 10 09:53:14 2017 (GMT +0200): [SRX5308] [IKE] INFO: 0.0.0.0 IP address has been released by remote peer. Mon Jul 10 09:53:14 2017 (GMT +0200): [SRX5308] [IKE] INFO: Received attribute type "ISAKMP_CFG_REPLY" from 31.159.216.207[500] Mon Jul 10 09:53:09 2017 (GMT +0200): [SRX5308] [IKE] INFO: ISAKMP-SA established for <MyPublicIP>[500]-31.159.216.207[500] with spi:bff7714a21b1656e:099b3f12ea7eb137 Mon Jul 10 09:53:09 2017 (GMT +0200): [SRX5308] [IKE] INFO: Sending Xauth request to 31.159.216.207[500] Mon Jul 10 09:53:09 2017 (GMT +0200): [SRX5308] [IKE] WARNING: Ignore INITIAL-CONTACT notification from 31.159.216.207[500] because it is only accepted after phase1. Mon Jul 10 09:53:09 2017 (GMT +0200): [SRX5308] [IKE] INFO: NAT not detected Mon Jul 10 09:53:09 2017 (GMT +0200): [SRX5308] [IKE] INFO: NAT-D payload matches for 31.159.216.207[500] Mon Jul 10 09:53:09 2017 (GMT +0200): [SRX5308] [IKE] INFO: NAT-D payload matches for <MyPublicIP>[500] Mon Jul 10 09:53:09 2017 (GMT +0200): [SRX5308] [IKE] INFO: For 31.159.216.207[500], Selected NAT-T version: RFC 3947 Mon Jul 10 09:53:09 2017 (GMT +0200): [SRX5308] [IKE] INFO: Received Vendor ID: DPD Mon Jul 10 09:53:09 2017 (GMT +0200): [SRX5308] [IKE] INFO: Received unknown Vendor ID Mon Jul 10 09:53:09 2017 (GMT +0200): [SRX5308] [IKE] INFO: Received Vendor ID: draft-ietf-ipsra-isakmp-xauth-06.txt Mon Jul 10 09:53:09 2017 (GMT +0200): [SRX5308] [IKE] INFO: Received Vendor ID: draft-ietf-ipsec-nat-t-ike-02 Mon Jul 10 09:53:09 2017 (GMT +0200): [SRX5308] [IKE] INFO: Received unknown Vendor ID Mon Jul 10 09:53:09 2017 (GMT +0200): [SRX5308] [IKE] INFO: Received unknown Vendor ID Mon Jul 10 09:53:09 2017 (GMT +0200): [SRX5308] [IKE] INFO: Received unknown Vendor ID Mon Jul 10 09:53:09 2017 (GMT +0200): [SRX5308] [IKE] INFO: Received unknown Vendor ID Mon Jul 10 09:53:09 2017 (GMT +0200): [SRX5308] [IKE] INFO: Received unknown Vendor ID Mon Jul 10 09:53:09 2017 (GMT +0200): [SRX5308] [IKE] INFO: Received unknown Vendor ID Mon Jul 10 09:53:09 2017 (GMT +0200): [SRX5308] [IKE] INFO: Received unknown Vendor ID Mon Jul 10 09:53:09 2017 (GMT +0200): [SRX5308] [IKE] INFO: Received unknown Vendor ID Mon Jul 10 09:53:09 2017 (GMT +0200): [SRX5308] [IKE] INFO: Received Vendor ID: RFC 3947 Mon Jul 10 09:53:09 2017 (GMT +0200): [SRX5308] [IKE] INFO: Beginning Identity Protection mode. Mon Jul 10 09:53:09 2017 (GMT +0200): [SRX5308] [IKE] INFO: Received request for new phase 1 negotiation: <MyPublicIP>[500]<=>31.159.216.207[500] Mon Jul 10 09:53:09 2017 (GMT +0200): [SRX5308] [IKE] INFO: Anonymous configuration selected for 31.159.216.207[500].
- DaneANETGEAR Employee Retired
I just want to follow-up on this. Were you able to access the articles and links I've shared and used them as your guide?
DaneA
NETGEAR Community Team
- vfandreaAspirant
I already did what described inte the link you reported, I also used them to configure the firewall for VPN. But I had no success. To be honest after a reboot of the firewall i was able to connect, but after that still the same problem.
Finally I decided to use a different device as VPN Server.
Hi vfandrea,
Welcome to the community! :)
Let me share the articles below. Kindly use it as your reference guide in setting up a VPN connection between an iOS device and SRX5308:
Application Notes for IPsec Policy supporting Apple iPhone VPN connectivity
How to Setup VPN with NETGEAR Firewall and iPhone / iPad - this is related to the FVS336Gv1 which is already EOL (End-of-Life). However, try to perform the steps indicated as a guide and it might work.
Here is another article I found online about setting up ExpressVPN on iOS devices (L2TP):
How to manually set up ExpressVPN on iOS devices (L2TP)
Let me share the articles below that I found online about setting up VPN connection between an Android device and SRX5308. Kindly use it as reference guide.
How to Configure PPP VPN between Android and ProSAFE Firewall
How to Set Up and Use ExpressVPN on Android 4.0 and Above
Some Android Phone users use the NCP Secure Android Client app. Kindly access the link below and you may want to try it as well:
DaneA
