KevinCloch
Jul 24, 2015Aspirant
VPN speed: windows8.1 accepting incomming vs hardware VPN
Hi, I have a Win8.1 virual machine running on a NAS and Win8.1 is accepting incoming connections(VPN). This is located at the office where I have an ISP connection 200Mbits/s down; 15Mbits/s up. At ...
- Oct 08, 2015
I've run into similar situations with speed and one of the best things you can do is set up a site-to-site connection. This way, all the vpn overhead is in the routers. I can max out our 4Mbit upload pipe where our servers are almost 600mi away using a site-to-site configuration.
KevinCloch
Aug 02, 2015Aspirant
FYI
I bought a FVS318N Prosave router.
PPTP passtrue remains les then 5mbits/s
I configured the FVS318N to receive IPSec client connection with the VPN client software of Netgear.
I get 9.85Mbits/s.
So this is close to the max connection speeds, as my upload of my ISP connection is 10Mbits/s
Thx for the advice on upgrading my router.
Kevin
BrianL2
Aug 02, 2015NETGEAR Employee Retired
Hi KevinCloch,
Congratulations! Hope you're happy on your our newly bought NETGEAR ProSafe VPN router. If you have any questions, just create a new topic or discussion.
"Teamwork makes the DREAM WORK"
Kind regards,
BrianL
NETGEAR Community
