Hiran
Oct 09, 2015Aspirant
VPN Users connecting to Network Shares
Hi All, I have been running into an issue with users connecting to netowork shares through a Netgear VPN connection (Netgear FS336g). The problem is onyl ONE user is able to access any share at ...
SamirD
Oct 12, 2015Prodigy
This sounds like an issue with the computer the share is on. Do this, try to both access the share from the local network and see if the problem still occurs.
Hiran
Oct 13, 2015Aspirant
I have already tried this. We are able to access the shares without any problems on the local network. The problem only occurs on with VPN users and only with the netgear router. If I were to change the VPN router to something else or use the windows built in VPN server all is fine.
- SamirDOct 14, 2015Prodigy
Gotcha. Definitly strange.
What are the protocol stacks on the computers with the shares? IP4/6? Netbios? Netgios over tcp/ip? IPX? Is the hardware between the different shares the same or different (nic, cpu, ram, etc)?
- HiranOct 17, 2015Aspirant
The hardware is different between the shares which tells me that it is not the hardware. All different nic's and cpu's. Ram must be different as well. Everyone on ipv4, dhcp. Only the server has a static ip outside of the DHCP pool.
- SamirDOct 17, 2015Prodigy
Any OS limitations on network shares?
Is the server static IP able to be pinged? If so, can you assign a static IP to a share and see what happens? A shot in the dark, but maybe it will tell us something.
