nettyuser
Apr 16, 2018Aspirant
VPNG01L VPN Prosafe Client activation Error #54
Software activation is failing. I'm receiving the following "Activation not completed" ... "Activation Error 54: The Activation Server is unreachable.".. I've tried disabling the firewall and an...
- Apr 17, 2018
Is your computer already using Windows 8 before or was just updated to Windows 8?
Since you have already tried to disabled both the Windows firewall and anti-virus, kindly try to uninstall the anti-virus software in your Windows 8 PC and check if same problem will occur.
Also, if ever you are not using the latest version of the VPNG01L, I suggest you to install it on your PC. You can download the latest VPNG01L Professional Software Version 6.40.004 here.
DaneANETGEAR Community Team
DaneA
Apr 16, 2018NETGEAR Employee Retired
Hi nettyuser,
Welcome to the community! :)
Your VPN Client Lite license key needs to be reset. Kindly send me via private message the following below and I'll request the higher tier of NETGEAR Support to reset the VPN Client Lite license key:
a. the exact VPN Client Lite license key
b. the e-mail address that was used to register the VPN Client Lite license key
DaneA
DaneA
Apr 17, 2018NETGEAR Employee Retired
I got a feedback from the higher tier of NETGEAR Support that your VPN Professional Client software license key has been reset. Kindly try to register it again in your computer.
If ever you don't have further inquiries and since your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
- nettyuserApr 17, 2018Aspirant
I'm still not able to activate the software. The same error is being reported -having disabled anti-virus and windows firewall. Windows 8.
- DaneAApr 17, 2018NETGEAR Employee Retired
- nettyuserApr 18, 2018Aspirant
I'm a little suprised that I'd have to uninstall the AV program as I initially installed the ProSafe VPN client ( NETGEARVPNClientPro_Setup_V6.40.004 ) with it running back in October 2017.
Would starting the computer in safe mode w/networking achieve the same as uninstalling the anti-virus program? As such, the AV program is not running and I still cannot activate the software.
Can Netgear tech support activate the software provided my computer's mac address?
