nettyuser's avatar
nettyuser
VPNG01L VPN Prosafe Client activation Error #54
Software activation is failing.  I'm receiving the following "Activation not completed" ... "Activation Error 54: The Activation Server is unreachable."..   I've tried disabling the firewall and an...
  • DaneA's avatar
    DaneA
    Apr 17, 2018
    nettyuser,
    Is your computer already using Windows 8 before or was just updated to Windows 8?
    Since you have already tried to disabled both the Windows firewall and anti-virus, kindly try to uninstall the anti-virus software in your Windows 8 PC and check if same problem will occur.
    Also, if ever you are not using the latest version of the VPNG01L, I suggest you to install it on your PC.  You can download the latest VPNG01L Professional Software Version 6.40.004 here.
    DaneA
    NETGEAR Community Team
ProSupport for Business
