LAK1
Jan 02, 2019Aspirant
VPNG05L Error code 33
Hello, I´ve formatted my laptop and reinstall vpn ipsec client but when I try to activate the software I get error code 33 (the license is already activated in other device).
How can I activate the software once again.
Regards.
LAK1,
As per checking, you have 3 active licenses and we already reset the one that you sent. Please check if you can now install it.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
- JohnC_VNETGEAR Employee Retired
Hi LAK1,
Welcome to our community! :)
May you be able to send me via pm the license key and the email address that needs to be fix? I'll look forward to your message.
- LAK1Aspirant
Hi JohnCarloV,
i´ve sent you a pm.
Regards
LAK1,
- Jan 17, 2016Retired_Member
