KrunoB
May 22, 2018Aspirant
VPNG05L need licence key reset
HI! I reinstalled my computer on new disk. Old disk is still in computer. I uninstalled VPN Softweare from old disk before reinstalling OS on new disk. After instaling VPN softweare on new disk I get...
- May 22, 2018
I just got a feedback from the higher tier of NETGEAR Support that the VPN license key has been reset on the specified e-mail you have sent via private message. Kindly check it on your end.
If ever your concern has been addressed or resolved and you do not have further concerns, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
NETGEAR Community Team
DaneA
May 22, 2018NETGEAR Employee Retired
DaneA
