thomaskrampe
Jul 07, 2017Aspirant
WAN Load Balancing with FritzBox doesn't work
I curently have a FVS336Gv3 with a WAN2 connection to a Fritzbox 6490 Cable with static public IP adresses. LAN Port 1 on the FritzBox is connected to WAN2 on the FVS336Gv3. Iconfigure the with a st...
JohnC_V
Jul 12, 2017NETGEAR Employee Retired
I would to have a follow-up on this. If you were able to test the other fritzbox as a primary WAN just to test if it will work. Please keep us posted.
