remltr's avatar
remltr
WAN to LAN throughput FVS318G
I have a FVS318G which is 5 years old. Just got hooked up with Comcast business class. Direct connection to modem yields 85mbs wired.
Via the FVS318G it is 15mbs. Can someone point me to what settings I need to make or adjust to get the advertised throughput of 250mbs? Granted it can't ouput more than the modem at 85mbs, but hopefully you get my point.
Also the LAN is quite slow when everybody is up and running on the peer to peer network. Is there anyway to improve that as well? It is a 1Gb network.
Thanks for any information that you can provide.
  • JennC's avatar
    JennC
    NETGEAR Employee Retired
    Hello remitr,
    I have some questions to ask, listed them below:
    • What is the brand name of the modem?
    • What is the hardware version of your FVS318G?
    • What is the current firmware version?
    • remltr's avatar
      remltr
      Hi Jenn,
      Modem: Cisco Model DPC 3941B
      Hardware version : Not sure where to find that. Nothing shows on the 192.168.1.1 webpage or on the device itself.
      Firmware: 3.1.1-18
      Thanks for responding. Hope you can help me.
      Dave
      • JennC's avatar
        JennC
        Hello remitr,
        Cisco DPC3941B is a cable gateway. This means it has router capability. What WAN IP address is the FVS318G getting from the CIsco? You can give just at least the first 2 octets.
ProSupport for Business
