soosang's avatar
soosang
What gbic should I use for the sfp+ port of pr60x???
I heard that the axc761 cable was compatible with pr60x, so I bought a third-party cable that was identical to the axc761, but it did not work.
Also, I connected the pr60x and m4300 with several gbics, but most of them link down, and only the intel gbic links up. Even with this, the connection works fine from the pr60x to the m4300, but the link from the m4300 to the pr60x is broken.
I have several m4300s and they all operate normally. Multiple GBICs are also compatible with m4300.
Also, all other ports of pr60x operate normally. Only the sfp+ port does not work properly.
Also, cable works fine too.
Am I using an incompatible gbic or is the pr60x defective?
ProSupport for Business
