timatcg's avatar
timatcg
500 Internal Server Error WAX214 after firmware upgrade
I setup 4 WAX214 WAPs yesterday and as a final thought I upgraded the firmware to the latest version. However one seems to have failed as I now receive error "500 Internal Server Error". Everything else seems to be working on it however as I can connect to the "Config only" SSID and see it on the network. I've tried factory reset several times with no luck. My guess is that the web files have corrupted during the upgrade and just need reuploading but can't see a way to do it. Any help would be appreciated.
  • RaghuHR's avatar
    RaghuHR
    NETGEAR Expert
    Hi timatcg  Do you know from which firmware version was there initially? And you have upgraded to 1.0.3.3 firmware?
    • timatcg's avatar
      timatcg
      I'm 99% sure they were on version 1.0.1.0 and upgraded to 1.0.3.3.
      • RaghuHR's avatar
        RaghuHR
        NETGEAR Expert
        Hi timatcg  Press  HW reset button over 10 seconds. Then, device will go back to factory reset.
ProSupport for Business
