stuartsiegler's avatar
Aug 09, 2022
AC1200/WAC104 cant reset password
I just purchased an AC1200/WAC104 and on initial launch prompts for "Please change your password!"
I have tried password, sharedsecret, "" ,and everything else I could think of, but returns "Unauthorized" and returns to 401_access_denied.
Ideas?
1 Reply
  • plemans's avatar
    The default log/password should be:
    login: admin
    password: password
    all lower case.
    Try factory resetting it by pushing and holding reset for 7-15 seconds while powered on.
    during the install, it'll initially ask you for the login/password and then should prompt you to change it.
ProSupport for Business
