hillbear
Oct 07, 2022Follower
Access Point WAX204 - can't access it on network
Hi I have a new WAX204 and I am trying to install. Plug it into Billion router via yellow LAN port - all LEDS Ok. I then do a 'arp -a' on a networked PC - looks fine , gives an IP address, in this c...
schumaku
Oct 07, 2022Guru - Experienced User
The formal installation process depends on the initial firmware version in place. Consult https://www.netgear.com/support/product/wax204.aspx#docs FMI.
