Lascar77
Dec 17, 2022Aspirant
Accessing Interface WAC104
Hi i just got an new WAC104 access point, and i cannot by any means i know access it's interface. The proposed guide in the box does not work. Using my knowledge of manual setup i used on previous ro...
schumaku
Dec 17, 2022Guru - Experienced User
Scratch anything. Strictly stick to 100% with the installation guide: https://www.downloads.netgear.com/files/GDC/WAC104/WAC104_IG_EN.pdf
Step 2. Join the AP’s WiFi network
Step 3. Log in to the local browser UI Troubleshooting tips
Launch a web browser on a WiFi-enabled device that has a WiFi connection to the
AP (see Step 2. Join the AP’s WiFi network) and enter http://www.aplogin.net or
http://www.aplogin.com in the address field.
These URLs are the same as the IP address 192.168.0.100.
A login window displays.
2. Enter the AP user name and password.
The user name is admin. The default password is password. The user name and
password are case-sensitive.
or use the password previously configured.
Lascar77 wrote:
Using my knowledge of manual setup i used on previous routers and access points i have tried static ip and windows network discovery and such. But to no avail.
So what are you taking away from this? Its what it is. Would love to tell you the common sense accessing the WAC104 over the LAN is possible. Of course, a "normal" AP behavior would be great RaghuHR please.
Lascar77
After a third factory reset, now it works using aplogin.com. This makes me sweat.
- schumakuDec 17, 2022Guru - Experienced User
Excellent!
For my own curiosity Can the WAC104 now accessed direct from your other wireless or wired network using the WAC104 it's (current assigned) LAN IP address?
This safes me from buying a piece of hardware just to help other Netgear WAC104 customers.
