Lascar77
Dec 17, 2022Aspirant
Accessing Interface WAC104
Hi i just got an new WAC104 access point, and i cannot by any means i know access it's interface. The proposed guide in the box does not work. Using my knowledge of manual setup i used on previous ro...
Lascar77
Like i said. I did all that to access the web interface using a mobile machine connected via wifi also. Also tried everything on local lan side. If you read carefully i said i followed the whole instructions as described.
schumaku
Dec 17, 2022Guru - Experienced User
So please provide some basic insights like screenshots of the wireless client associated to that WAC104 access point from both the client as well as from the AP side and from the router and network (LAN) view.
One part of the RTFM is this crucial "http://www.aplogin.net" and "http://www.aplogin.com" access.
A result of a ping or nslookup (for example) would be brilliant.
Yes, I could imagine customers are operating interesting router or network config with proxies, crazy Internet "security" software, or other i-know-better designs like allowing some encrypted DNS only.
