Whoeverknowsit
Aug 19, 2024Aspirant
AP compatible with C6250 router or is there a better option?
I have a C620 Wireless Router/Modem connected to Comcast coax that cannot be moved. On the opposite side of my house I have a game room with a TV mounted over a brick fireplace which cannot pick up th...
Aug 19, 2024Guru - Experienced User
The WAX214/218 are non-insight managed. I've used the WAX218 without issues.
Or you could switch to a newer system. with xfinity doing all their "next gen" upgrades, upgrading the modem isn't a bad plan too. the C6250 is an older/slower modem.
