Whoeverknowsit
Aug 19, 2024Aspirant
AP compatible with C6250 router or is there a better option?
I have a C620 Wireless Router/Modem connected to Comcast coax that cannot be moved. On the opposite side of my house I have a game room with a TV mounted over a brick fireplace which cannot pick up th...
Whoeverknowsit
Thanks for your help! I am open to switching to a newer modem if necessary. I am not very knowledgeable on this subject. If I get the WAX218 I'm assuming that I would have to manually switch to the stronger connection depending on where i am at in the house, since it is not managed? Would a newer modem setup allow active management without a subscription or do most active systems require a subscription regardless?
Aug 19, 2024Guru - Experienced User
The problem is you want POE.
there isn't a mesh poe system from netgear.
