NullZer013
Sep 02, 2022Initiate
AX3200 (dual band access port) WAX206 Connected without internet
The router will power on but the 5ghz light will constantly blink blue. I am able to connect to the wifi that has been set up but it doesn't have internet ( To clarify I'm in a dorm room in a college ...
- Sep 02, 2022
a couple tings.
1. the WAX has a router mode and an extender mode. both are going to function a bit differently. What mode are you trying to set it up in?
2. Many dorms supply their own internet connection for you. But its for connecting a pc/laptop to and not another routing device. If you're wanting to attach your own router, you might have to talk to the IT department there for them to allow the WAX to be connected to their network
NullZer013
Sorry, but I have already solved this issue, I just needed to go through the full setup. Thank you anyway.
Sep 02, 2022Guru - Experienced User
glad you got it fixed. sorry my post should have said router and access point mode. not extender mode.
