BGalehouse
Oct 16, 2023Aspirant
AX4200 Management VLAN, Static IP incompatible?
I have a few AX4200s at home. They are configured to use 3 different static IPs for their management interface. I'm running 3 explicit vlans - 1001 for management, 1002 and 1003 for different classes...
BGalehouse
schumaku wrote:Not convinced these WAX2xx allow defining a management VLAN -and- a static LAN IP for the management.
Said that, I strongly doubt your management VLAN is already on the VLAN you expect it to be. Strongly suggest to double check your unknown magic router does correctly assign DHCP addresses in the appropriate VLAN subnet.
WAX220 let me set it up that way - first changing the VLAN, then to a static IP. But this put it in a state where I cannot make more wireless changes. So I guess it is effectively unsupported/broken by design. As I said though, I'll revert the static IP setting, at least from the APs viewpoint and that will probable work around it.
I'm quite certain at this point that the router is doing the right thing. Previously I used a Mikrotik with this VLAN structure, now I use an Arch box. In both cases you set up a virtual interface for each VLAN and go from there with a dhcp pool configuration for each and so on and so forth.
schumaku
Oct 16, 2023Guru - Experienced User
If you believe the router port config is correct, change the VLAN config to the tagged management port (and set the WAX220 to DHCP) - not connect the WAX20 direct to the router. Nothing that stops you from this test. Now time to configure the switch correct to use the tagged VLAN trunks.
The switch message was very clear: "Current IPv4 setting is set as Static, not allow user to Enable Management VLAN". Isn't it? So return to DHCP, re-activate the management VLAN, ... No short cuts supported. The price for deploying Business Essentials line models I guess.
Have managed to configure the VLAN trunks required on the switch accordingly in the meantime?
- BGalehouseOct 16, 2023Aspirant
The message "Current IPv4 setting is set as Static, not allow user to Enable Management VLAN" is from any AP, when I try to further adjust wireless settings. It is not a message from the switch.
I'm convinced the message is a firmware bug, because the management VLAN is already set and operational on the APs. In particular, the error message arrives over the management VLAN, from the static IPs, because that is how I access the AP web interfaces. Also, the management VLAN isn't something that I'm trying to change at this point, but is pre-populated as 1001 on the wireless settings page.
- schumakuOct 17, 2023Guru - Experienced User
Yes, my bad, lack of sleep along time after midnight. Talking of the WAX220 here. Conclude, the WAX220 was never enabled for the tagged management VLAN, because it does not allow enabling the management VLAN.
Seriously think the WAX220 magically changing the VLAN, despite having a static IP configured, and under the impression you are accessing the WAX220 over the management VLAN (despite not having configured the switch accordingly). I'm about to bet on a beer you still access the WAX220 over the untagged network my new friend.
The wireless settings page defines the SSID<->VLAN relation only. Easy possible operating the same IP subnet over tagged and untagged connections.
