Maruha
Oct 16, 2025Aspirant
Bestehendes WLan erweitern
Guten Tag, ich bin auf der Suche nach einer Lösung für folgende Frage. Ich betreibe im Wohnhaus ein funktionierendes WLan, bestehend aus 3 Stück WAC720, alle mit aktueller Firmware, alle via ...
Oct 17, 2025Guru - Experienced User
How far apart are these 2 outbuildings? you might pickup a point to point system like netgear airbridge (not in stock right now) to connect them that route if they're to far apart.
- MaruhaOct 17, 2025Aspirant
Hi plemans,
thanks for this suggestion. The distance from the main building to the outbuildings is about 25 meters. The main building is located in the middle between the outbuildings.
I will double check this as an alternative to my first idea ;-)
Kind regards
Matthias
